[GRASS-dev] access to grass (trunk 7.0.svn ) vector map from python
Wed Jun 16 11:13:14 EDT 2010
Fernando Pacheco wrote:
> I think there is an error in the generation process with ctypesgen for
> vector.py. The problem is that "dig_estructs.h" needs the heading
> "ogr_api.h" which is not found in the path included. The problem is solved
> if you add the path to that file (in my case -I/usr/include/gdal).
Try r42567.
