[GRASS-dev] Re: [GRASS GIS] #1090: Access is denied - r.statistics
GRASS GIS trac at osgeo.org
Thu Jun 17 13:59:33 EDT 2010
 Reporter:  nkale                                 |       Owner:  grass-dev@…
     Type:  defect                                |      Status:  new
 Priority:  normal                                |   Milestone:  6.4.0
Component:  Raster                                |     Version:  6.4.0 RCs
 Keywords:  r.statistics access denied, wingrass  |    Platform:  MSWindows 7
      Cpu:  x86-32                                |
Comment(by nkale):
 Replying to [comment:3 hamish]:
 > could you give the grass 7 daily snapshot a try? it uses an improved
 method to generate the stats and hopefully bypasses the problem.
 > system() replaced with G_system() in grass 6.5svn with r42570, daily
 WinGrass snapshots for 6.5 are probably broken until bug #1089 gets fixed,
 and it this wants testing there before backporting to 6.4.
 > cheers,
 > Hamish
 That worked.  Ran with a slightly smaller dataset (didn't know if the
 raster format was the same between 6 & 7, so I had to do some lengthy re-
 importing), but I didn't get any errors, and the output map made sense.
 On the other hand, in 7 I can no longer launch GRASS in MSYS mode, but
 that's maybe a bug for another ticket.
 Thanks,
 Nat
Ticket URL: <https://trac.osgeo.org/grass/ticket/1090#comment:4>
