[GRASS-dev] Re: [GRASS GIS] #1092: WinGrass + R's installation path in %PATH%
GRASS GIS trac at osgeo.org
Sat Jun 19 12:47:29 EDT 2010
 Reporter:  hellik       |       Owner:  grass-dev@…
     Type:  enhancement  |      Status:  new
 Priority:  normal       |   Milestone:  6.4.0
Component:  Packaging    |     Version:  svn-releasebranch64
 Keywords:  wingrass, R  |    Platform:  MSWindows Vista
      Cpu:  Unspecified  |
Comment(by hellik):
 Replying to [ticket:1092 hellik]:
 > I have installed the WinGrass64-installer and R 2.11.1 on my
 WinVista32-box.
 > the wingrass-installer delivers a command line.
 > in the command line during a Grass-session you can change to the
 installation folder of R
 > and then you are able to start R inside a Grass-session.
 > it would be nice to have the R's installation path in %PATH%, so you can
 start R directly
 > in the WinGrass-delivered command line.
 > From the R-Windows-FAQ:
 > (http://cran.r-project.org/bin/windows/base/rw-FAQ.html#Does-R-use-the-
 Registry_003f)
 > "Does R use the Registry?" => this would maybe a starting point
 > maybe something for 6.4.1?
 > best regards
 > Helmut
 patches added for Grass64, Grass65, Grass7.
 this improves the Grass+R-integration on Windows (in the case R is
 installed before a grass-installation).
 any comments?
 Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1092#comment:2>
