[GRASS-dev] GRASS 6.6 trunk GUI doesn't open
Paulo pvanbmail-guard at yahoo.com
Mon Jun 21 05:49:58 EDT 2010
I am always using 'svn update' to get the latest revision, shouldn't
that just replace old code with updates?
In any case, I downloaded the source in a new folder and that indeed
compiled without problem.
Thanks,
Paulo
On 06/21/2010 11:43 AM, Martin Landa wrote:
> Hi,
> 2010/6/21 Paulo<pvanbmail-guard at yahoo.com>:
>> line 278, in __createMenu
>>      self.__createMenuItem(menu, *eachItem)
>>    File "/usr/local/grass6.4.current/grass-6.4.0svn/etc/wxpython/wxgui.py",
>> line 302, in __createMenuItem
>>      rhandler = eval(handler)
>>    File "<string>", line 1, in<module>
>> AttributeError: 'GMFrame' object has no attribute 'DispMapCalculator'
> you are probably using out-dated code (try to run `svn up`).
> DispMapCalculator has been renamed to OnMapCalculator, see
> http://trac.osgeo.org/grass/browser/grass/branches/releasebranch_6_4/gui/wxpython/xml/menudata.xml#L860
> andhttp://trac.osgeo.org/grass/browser/grass/branches/releasebranch_6_4/gui/wxpython/wxgui.py#L1073.
> Martin
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20100621/96e640f8/attachment.html
