[GRASS-dev] GRASS6.4 Ptyhon scripts- module
António Rocha antonio.rocha at deimos.com.pt
Mon Jun 21 12:12:07 EDT 2010
Greetings
I was developing a special import script (for a designated dataset) and
I used r.in.aster Python Script (GRASS7) as a based for this Python
script in GRASS6.4.. It compiled but I got this error:
make: Entering directory `/home/anrr/Desktop/dwe_devep/r.in.globcover.py'
if [ ! -d /usr/local/grass-6.4.0svn/scripts ]; then mkdir -p
/usr/local/grass-6.4.0svn/scripts; fi
/usr/bin/install -c  r.in.globcover.py
/usr/local/grass-6.4.0svn/scripts/r.in.globcover.py
make htmlscript scriptstrings
make[1]: Entering directory `/home/anrr/Desktop/dwe_devep/r.in.globcover.py'
make /usr/local/grass-6.4.0svn/docs/html/r.in.globcover.py.html
HTMLSRC=/usr/local/grass-6.4.0svn/scripts/r.in.globcover.py
make[2]: Entering directory `/home/anrr/Desktop/dwe_devep/r.in.globcover.py'
if [ "/usr/local/grass-6.4.0svn/scripts/r.in.globcover.py" != "" ] ;
then GISRC=/usr/local/grass-6.4.0svn/demolocation/grassrc64
GISBASE=/usr/local/grass-6.4.0svn
PATH="/usr/local/grass-6.4.0svn/bin:$PATH"
LD_LIBRARY_PATH="/usr/local/grass-6.4.0svn/bin:/usr/local/grass-6.4.0svn/lib:"
LC_ALL=C /usr/local/grass-6.4.0svn/scripts/r.in.globcover.py
--html-description < /dev/null | grep -v '</body>\|</html>' >
r.in.globcover.py.tmp.html ; true ; fi
  File "/usr/local/grass-6.4.0svn/scripts/r.in.globcover.py", line 50,
in <module>
    import grass.script as grass
*ImportError: No module named grass.script*
I thought GRASS6.4 Python's script already had this module. Is not
available?
Just one last question: How can I retrieve image projection, using a
Python script, with tghe same information-structure I get when I use:
grass.read_command('g.proj', flags = 'jf').strip()
Thanks
Best regards,
Antonio Rocha
__________ Information from ESET NOD32 Antivirus, version of virus signature database 5215 (20100621) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
