[GRASS-dev] Segmentation fault i.smap
Markus Neteler neteler at osgeo.org
Tue Jun 29 11:12:09 EDT 2010
On Tue, Jun 29, 2010 at 4:38 PM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> Markus Neteler wrote:
>> using i.smap, I get a segfault:
>> #0  0x000000000040295d in write_img (img=0x75e950, ncols=210,
>> nrows=215, S=0x7fff87ab2a60, parms=0x7fff87ab2ba0,
>> files=0x7fff87ab2a80) at write_img.c:23
>>        class = 0
>>        row = 0
>>        col = 0
>> I don't see the problem in the backtrace output... ("isdata" looks strange?).
> You would need to look at the structures referenced by "S" and
> "files"; the pointers alone don't suffice.
>> It crashes in i.smap/shapiro/write_img.c line 23:
>>                 files->outbuf[col] = (CELL) S->ClassSig[class].classnum;
>> #2  0x000000000040216b in main (argc=5, argv=0x7fff87ab2cc8) at main.c:48
>>        S = {nbands = 17, nclasses = 0, title = 0x74c320 " Labels",
>> ClassSig = 0x0}
> It looks like S->ClassSig is NULL, hence the segfault.
> This suggests that the sigset file doesn't have a "class:" tag or is
> broken.
That's indeed true (I am debugging data of a colleague, apparently his
i.gensigset
run failed unnoticed):
cat sig_22_1684
title: Labels
nbands: 17
The "only" thing to do seems to catch such error of "emtpy" signature
file without
crashing.
Markus
