[GRASS-dev] Re: [GRASS GIS] #974: [Patch] add option to d.vect to make symbol size proportionate to square root of size_column
GRASS GIS trac at osgeo.org
Tue Mar 2 05:40:26 EST 2010
root of size_column
  Reporter:  mlennert     |       Owner:  grass-dev at lists.osgeo.org
      Type:  enhancement  |      Status:  closed
  Priority:  normal       |   Milestone:  7.0.0
 Component:  Display      |     Version:  unspecified
Resolution:  fixed        |    Keywords:
  Platform:  Unspecified  |         Cpu:  Unspecified
Changes (by mlennert):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Replying to [comment:1 hamish]:
 > I'm fine with the patch, a couple of comments though,
 >  - patches are '''''much''''' easier to review if they are kept to just
 the change you are talking about. ie gratuitous whitespace changes should
 be put in another patch if at all. signal:noise ratios & wasted time ...
 >  - please don't run the indent script unless you've added a bunch of new
 code which needs it. see the comments in the SUBMITTING file.
 Sorry, thought indent should always be run. But understand the point and
 won't do it again ;-)
 >  - if using sqrt() please #include <math.h>
 >  - sqrt_flag->description: please split into two parts: short
 description on flag->label= line and "i.e." on flag->description= line (it
 becomes the tooltip).
 I've just committed a corrected version of the patch to trunk.
 Closing this and responding to the other issues on the mailing list.
 Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/974#comment:2>
