[GRASS-dev] Re: [GRASS GIS] #978: wxGUI: files without extensions are not visible in file dialogs
GRASS GIS trac at osgeo.org
Thu Mar 4 07:52:43 EST 2010
  Reporter:  msieczka  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect    |      Status:  closed
  Priority:  major     |   Milestone:  6.4.0
 Component:  wxGUI     |     Version:  svn-releasebranch64
Resolution:  fixed     |    Keywords:
  Platform:  All       |         Cpu:  All
Changes (by mlennert):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Replying to [comment:3 mlennert]:
 > Replying to [comment:2 glynn]:
 > > Replying to [comment:1 hamish]:
 > > > I don't know where this is defined in the code source,
 > > The code uses wx.lib.filebrowsebutton, which uses *.* as the default
 value for its fileMask parameter.
 > > > but in my eyes
 > > > there should be the possibility to "show all files", so looking for
 > > > and not *.*, maybe even replacing *.* by *
 > > Try `filebrowse.FileBrowseButton(..., fileMask = '*')`
 > Fixed in #41284. Can this be backported to deb6 and rel6 ?
 Done: r41287 and r41288.
Ticket URL: <https://trac.osgeo.org/grass/ticket/978#comment:5>
