[GRASS-dev] Location wizard (missed window to select +towgs params)
Markus Neteler neteler at osgeo.org
Fri Mar 12 14:45:49 EST 2010
On Fri, Mar 12, 2010 at 8:38 PM, Martin Landa <landa.martin at gmail.com> wrote:
> Hi,
> 2010/3/12 Massimo Di Stefano <massimodisasha at gmail.com>:
>>  "location wizard -> select epsg code -> search for : 3004"
>> in the paste release (build less than 1 month ago) after select the epsg:code(3004)
>> grass prompt me to the window :
>> http://img534.imageshack.us/img534/8254/schermata20100312a09564.png
>> to select the +towgs parameters
>> with the latest svn version this window doesn't appair and  the locaqtion is created using the defaults parameters :
> it seems to be bug in g.proj -
> g.proj epsg=3004 datum=-1
> no output is printed...
When you add -t, it works:
g.proj epsg=3004 datum=-1 -t
Markus
