[GRASS-dev] Re: [GRASS GIS] #998: v.colors color column selection bug - default GRASSRGB not show in dialog
GRASS GIS trac at osgeo.org
Sat Mar 13 13:21:54 EST 2010
  Reporter:  neteler      |       Owner:  martinl
      Type:  defect       |      Status:  assigned
  Priority:  normal       |   Milestone:  6.4.0
 Component:  wxGUI        |     Version:  svn-releasebranch64
Resolution:               |    Keywords:  v.colors, columns
  Platform:  Unspecified  |         Cpu:  Unspecified
Changes (by martinl):
 * cc: grass-dev at lists.osgeo.org (added)
  * owner:  grass-dev at lists.osgeo.org => martinl
  * status:  new => assigned
Comment:
 Replying to [ticket:998 neteler]:
 > When using v.colors via wxGUI, the default GRASSRGB is not show in the
 dialog
 > but instead all existing table columns (see screenshot).
 > In d.vect, the column selector in the "Colors" tab is deactivated (also
 > confusing).
 > For all such color column selectors, the "GRASSRGB" should be predefined
 > and be the first choice in the color column selector.
 Please try r41425. Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/998#comment:2>
