[GRASS-dev] [GRASS GIS] #1008: WinGrass7 - disable LFS
GRASS GIS trac at osgeo.org
Sun Mar 14 14:15:27 EDT 2010
 Reporter:  hellik     |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect     |      Status:  new
 Priority:  normal     |   Milestone:  7.0.0
Component:  Compiling  |     Version:  svn-trunk
 Keywords:  wingrass   |    Platform:  MSWindows Vista
      Cpu:  x86-32     |
 from the dev-ml:
 Sun Mar 14 03:10:19 EDT 2010
 > >Has disabling LFS to be set explicitly for configure in the windows-
 world?
 > I've tried --disable-largefile,
 > but again there is
 > checking if system supports Large Files at all... yes
 > Large File support (LFS):   yes
 > in the build-log.
 > what have to be done to disable LFS for building WinGrass7?
 configure.in is broken; it sets USE_LARGEFILES according to whether
 LFS is detected, regardless of whether it is enabled. MinGW has LFS,
 but it's not in a form which currently works with GRASS.
 what are the differences to 6.4/6.5? both are compiling on WinVista32.
 Helmut
Ticket URL: <https://trac.osgeo.org/grass/ticket/1008>
