[GRASS-dev] Re: [GRASS GIS] #1008: WinGrass7 - disable LFS
GRASS GIS trac at osgeo.org
Mon Mar 15 14:07:36 EDT 2010
  Reporter:  hellik           |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect           |      Status:  new
  Priority:  normal           |   Milestone:  7.0.0
 Component:  Compiling        |     Version:  svn-trunk
Resolution:                   |    Keywords:  wingrass
  Platform:  MSWindows Vista  |         Cpu:  x86-32
Comment (by glynn):
 Replying to [comment:2 hellik]:
 > so Grass7-compiling on Win-OS 32-bit and testing won't be possible (at
 the moment)?
 Remind me again: what is being broken by the LFS mis-detection?
 I occasionally compile and test 7.0 on Win32 (Windows XP), and haven't
 noticed any problems, but I haven't tested it thoroughly.
 The one thing which I remember is that "make test" in lib/vector/diglib
 fails (it compares the output against test64.ok and fails because of the
 32-bit off_t).
 You could just modify Platform.make by hand after running configure.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1008#comment:3>
