[GRASS-dev] Re: [GRASS GIS] #928: 6.4: wx module GUIs never return
GRASS GIS trac at osgeo.org
Tue Mar 16 04:24:12 EDT 2010
  Reporter:  hamish    |       Owner:  martinl
      Type:  defect    |      Status:  assigned
  Priority:  critical  |   Milestone:  6.4.0
 Component:  default   |     Version:  svn-releasebranch64
Resolution:            |    Keywords:  addons
  Platform:  Linux     |         Cpu:  x86-64
Comment (by hamish):
 Replying to [comment:13 martinl]:
 > Replying to [comment:11 hamish]:
 > > ps - `v.out.ascii input=roads --ui` fails to pre-seed the GUI
 > > as it does with tcktk.
 > hopefully fixed in r41447 (trunk) and r41448 (devbr6).
 thanks, works for me with a couple of minor points:
  - d.erase only works if color != white. (then answer disappears from
 command at bottom of window & I guess the command becomes recursive..?)
  - "`v.out.ascii roads fs=, --ui`": fs=, gets skipped but other values
 work. (I guess a syntax thing)
 > I would suggest to backport this change to relbr64 after 6.4.0.
 > It needs some testing and can affect wxGUI quite significantly.
 fine with me. the main point in supporting this is to give better control
 to the menus. (pre-tick non-interactive mode, etc)
 TODO: verify 6.4 wingrass with python addon script and the newly
 backported g.parser -s.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/928#comment:15>
