[GRASS-dev] Re: [GRASS GIS] #1038: v.surf.rst fails in Windows 7 with "Access is denied"
GRASS GIS trac at osgeo.org
Sun May 2 12:05:38 EDT 2010
  Reporter:  marisn       |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect       |      Status:  new
  Priority:  critical     |   Milestone:  6.4.0
 Component:  Vector       |     Version:  6.4.0 RCs
Resolution:               |    Keywords:  v.surf.rst, wingrass
  Platform:  MSWindows 7  |         Cpu:  Unspecified
Comment (by hellik):
 Replying to [comment:2 hamish]:
 > Hi,
 > I've no way of testing on XP right now. Can anyone reproduce this &
 provide debugging output?
 > Hamish
 taken from the dev-ml (http://lists.osgeo.org/pipermail/grass-dev/2010-
 May/050270.html)
 >> [*] ... can someone test if 6.4's v.surf.rst works on XP/Vista/7?
 >we have been running it all semester on XP/Vista/7 without any
 complaints,
 >but I would have to specifically
 >check who actually ran it with GRASS installed under Program Files.
 tested with the nightly-build  WinGRASS-6.4.SVN-r42075-1-Setup.exe
 (installed in c:\Program Files\ in WinVista32) and the example from the
 manual:
 Spearfish example (we simulate randomly distributed elevation measures):
 g.region rast=elevation.10m -p
 # random elevation extraction
 r.random elevation.10m vector_output=elevrand n=200
 v.info -c elevrand
 v.db.select elevrand
 # interpolation based on all points
 v.surf.rst elevrand zcol=value elev=elev_full
 r.colors elev_full rast=elevation.10m
 d.rast elev_full
 d.vect elevrand
 # interpolation based on subset of points (only those over 1300m/asl)
 v.surf.rst elevrand zcol=value elev=elev_partial where="value > 1300"
 r.colors elev_partial rast=elevation.10m
 d.rast elev_partial
 d.vect elevrand where="value > 1300"
 v.surf.rst is working.
 tried with the spearfish-example in the wx-gui-command-line and also the
 wx-gui for v.surf.rst in a WinVista32-box (Grass64 installed in the
 default c:\Program Files\ without any modifications).
 v.surf.rst is working in both ways.
 best regards
 Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1038#comment:3>
