[GRASS-user] Re: [GRASS-dev] raster interpolation and NULL cell filling
Fri May 7 08:19:51 EDT 2010
Markus Metz wrote:
> > BTW, this module should probably stay in `raster/` instead of `vector\lidar`.
> For compilation it is easier if it is in vector/lidar because it uses
> stuff in lidarlib. Otherwise it will fail because raster modules are
> compiled before vector modules ->lidarlib not yet available.
Should vector/lidar/lidarlib be moved to lib/lidarlib?
