[GRASS-dev] [GRASS GIS] #1072: It is too easy to accidentally delete all your data columns in the Attribute Table Manager
GRASS GIS trac at osgeo.org
Mon May 17 13:13:23 EDT 2010
 Reporter:  isaacullah                       |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect                           |      Status:  new
 Priority:  major                            |   Milestone:  6.4.0
Component:  wxGUI                            |     Version:  6.4.0 RCs
 Keywords:  Table Managere, Columns, Delete  |    Platform:  Linux
      Cpu:  x86-64                           |
 This isn't a bug per se, but it is much more than an enhancement request.
 When you right click on the column names in the "manage tables" tab of the
 Attribute Table Manager, you get a nice pull down with some options ("drop
 selected column, drop all columns, reload). This is great. However, the
 "drop all columns" function is dangerously close to the "drop selected
 column" option, and if you accidentally choose that, all columns are
 dropped instantly with out an "are you sure you want to do that?" message.
 Adding a second pop-up approval step for dropping columns would be a very
 very good feature to add in here. As it is now, you can instantaneously
 delete all data in a table with just one mis-click of the mouse, and there
 is no way to recover it. This is a serious issue which IMO should be
 remedied ASAP.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1072>
