[GRASS-dev] GRASS 7 not compiling on Mac OSX 10.6
Michael Barton Michael.Barton at asu.edu
Mon May 17 14:41:37 EDT 2010
I just updated from the CVS and tried to compile. I got errors at the end. I'm pretty sure that the ../gui/wxpython error is just a problem with the make file. But the ../lib/python error is something else. Here is the result.
Errors in:
/Users/cmbarton/grass_dev/grass70_dev/lib/python
/Users/cmbarton/grass_dev/grass70_dev/gui/wxpython
In case of errors please change into the directory with error and run 'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
Finished compilation: Mon May 17 11:30:51 MST 2010
make: *** [default] Error 1
cmb-mbp:grass70_dev cmbarton$ cd /Users/cmbarton/grass_dev/grass70_dev/lib/python
cmb-mbp:python cmbarton$ make
make -C ctypes
make /Users/cmbarton/grass_dev/grass70_dev/dist.i386-apple-darwin10.3.1/etc/python/grass/lib
make[2]: `/Users/cmbarton/grass_dev/grass70_dev/dist.i386-apple-darwin10.3.1/etc/python/grass/lib' is up to date.
make date.py grass.py raster.py gmath.py proj.py imagery.py vector.py display.py stats.py dbmi.py g3d.py arraystats.py cluster.py trans.py vedit.py /Users/cmbarton/grass_dev/grass70_dev/dist.i386-apple-darwin10.3.1/etc/python/grass/lib/date.py /Users/cmbarton/grass_dev/grass70_dev/dist.i386-apple-darwin10.3.1/etc/python/grass/lib/grass.py /Users/cmbarton/grass_dev/grass70_dev/dist.i386-apple-darwin10.3.1/etc/python/grass/lib/raster.py /Users/cmbarton/grass_dev/grass70_dev/dist.i386-apple-darwin10.3.1/etc/python/grass/lib/gmath.py /Users/cmbarton/grass_dev/grass70_dev/dist.i386-apple-darwin10.3.1/etc/python/grass/lib/proj.py /Users/cmbarton/grass_dev/grass70_dev/dist.i386-apple-darwin10.3.1/etc/python/grass/lib/imagery.py /Users/cmbarton/grass_dev/grass70_dev/dist.i386-apple-darwin10.3.1/etc/python/grass/lib/vector.py /Users/cmbarton/grass_dev/grass70_dev/dist.i386-apple-darwin10.3.1/etc/python/grass/lib/display.py /Users/cmbarton/grass_dev/grass70_dev/dist.i386-apple-darwin10.3.1/etc/python/grass/lib/stats.py /Users/cmbarton/grass_dev/grass70_dev/dist.i386-apple-darwin10.3.1/etc/python/grass/lib/dbmi.py /Users/cmbarton/grass_dev/grass70_dev/dist.i386-apple-darwin10.3.1/etc/python/grass/lib/g3d.py /Users/cmbarton/grass_dev/grass70_dev/dist.i386-apple-darwin10.3.1/etc/python/grass/lib/arraystats.py /Users/cmbarton/grass_dev/grass70_dev/dist.i386-apple-darwin10.3.1/etc/python/grass/lib/cluster.py /Users/cmbarton/grass_dev/grass70_dev/dist.i386-apple-darwin10.3.1/etc/python/grass/lib/trans.py /Users/cmbarton/grass_dev/grass70_dev/dist.i386-apple-darwin10.3.1/etc/python/grass/lib/vedit.py /Users/cmbarton/grass_dev/grass70_dev/dist.i386-apple-darwin10.3.1/etc/python/grass/lib/__init__.py /Users/cmbarton/grass_dev/grass70_dev/dist.i386-apple-darwin10.3.1/etc/python/grass/lib/date.pyc /Users/cmbarton/grass_dev/grass70_dev/dist.i386-apple-darwin10.3.1/etc/python/grass/lib/grass.pyc /Users/cmbarton/grass_dev/grass70_dev/dist.i386-apple-darwin10.3.1/etc/python/grass/lib/raster.pyc /Users/cmbarton/grass_dev/grass70_dev/dist.i386-apple-darwin10.3.1/etc/python/grass/lib/gmath.pyc /Users/cmbarton/grass_dev/grass70_dev/dist.i386-apple-darwin10.3.1/etc/python/grass/lib/proj.pyc /Users/cmbarton/grass_dev/grass70_dev/dist.i386-apple-darwin10.3.1/etc/python/grass/lib/imagery.pyc /Users/cmbarton/grass_dev/grass70_dev/dist.i386-apple-darwin10.3.1/etc/python/grass/lib/vector.pyc /Users/cmbarton/grass_dev/grass70_dev/dist.i386-apple-darwin10.3.1/etc/python/grass/lib/display.pyc /Users/cmbarton/grass_dev/grass70_dev/dist.i386-apple-darwin10.3.1/etc/python/grass/lib/stats.pyc /Users/cmbarton/grass_dev/grass70_dev/dist.i386-apple-darwin10.3.1/etc/python/grass/lib/dbmi.pyc /Users/cmbarton/grass_dev/grass70_dev/dist.i386-apple-darwin10.3.1/etc/python/grass/lib/g3d.pyc /Users/cmbarton/grass_dev/grass70_dev/dist.i386-apple-darwin10.3.1/etc/python/grass/lib/arraystats.pyc /Users/cmbarton/grass_dev/grass70_dev/dist.i386-apple-darwin10.3.1/etc/python/grass/lib/cluster.pyc /Users/cmbarton/grass_dev/grass70_dev/dist.i386-apple-darwin10.3.1/etc/python/grass/lib/trans.pyc /Users/cmbarton/grass_dev/grass70_dev/dist.i386-apple-darwin10.3.1/etc/python/grass/lib/vedit.pyc /Users/cmbarton/grass_dev/grass70_dev/dist.i386-apple-darwin10.3.1/etc/python/grass/lib/__init__.pyc
ctypesgen.py -I/Users/cmbarton/grass_dev/grass70_dev/dist.i386-apple-darwin10.3.1/include -I/Users/cmbarton/grass_dev/grass70_dev/dist.i386-apple-darwin10.3.1/include -L/Users/cmbarton/grass_dev/grass70_dev/dist.i386-apple-darwin10.3.1/lib -L/Users/cmbarton/grass_dev/grass70_dev/dist.i386-apple-darwin10.3.1/lib -lgrass_datetime  /Users/cmbarton/grass_dev/grass70_dev/dist.i386-apple-darwin10.3.1/include/grass/datetime.h /Users/cmbarton/grass_dev/grass70_dev/dist.i386-apple-darwin10.3.1/include/grass/P_datetime.h -o date.py
make[2]: ctypesgen.py: No such file or directory
make[2]: *** [date.py] Error 1
make[1]: *** [default] Error 2
make: *** [default] Error 2
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
voice: 	480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax:          480-965-7671 (SHESC),  480-727-0709 (CSDC)
www: www.public.asu.edu/~cmbarton, http://csdc.asu.edu
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20100517/03d55d86/attachment.html
