[GRASS-dev] RE: [GRASS-user] Question with Python-SWIG example [SEC=UNCLASSIFIED]
Martin Landa landa.martin at gmail.com
Sun May 23 18:49:01 EDT 2010
2010/5/23 Glynn Clements <glynn at gclements.plus.com>:
> Not only can I not reproduce this, I can't see any mechanism by which
> it can occur. Have you done "make clean"? What is the value of
yes (make distclean)
> grass.__file__ after importing it?
>>> from grass.lib import grass
>>> grass.__file__
'/usr/local/src/grass_trunk/dist.i686-pc-linux-gnu/etc/python/grass/lib/grass.pyc'
> Given that ctypes_preamble.py defines:
>        String = c_char_p
>        ReturnString = c_char_p
right,
> it shouldn't be possible for this:
>        G_find_raster2.argtypes = [c_char_p, c_char_p]
>        G_find_raster2.restype = c_char_p
> to work but this:
>        G_find_raster2.argtypes = [String, String]
>        G_find_raster2.restype = ReturnString
Here I am getting
  File "/home/martin/smetiste/example7.py", line 8, in <module>
    grass.G_find_raster2.argtypes = [String, String]
NameError: name 'String' is not defined
even ctypes are imported (from ctypes import *).
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
