[GRASS-dev] grass7 on mac OSX
Michael Barton michael.barton at asu.edu
Mon May 24 11:28:42 EDT 2010
On May 24, 2010, at 6:35 AM, grass-dev-request at lists.osgeo.org wrote:
> Date: Mon, 24 May 2010 00:49:51 +0200
> From: Massimo Di Stefano <massimodisasha at gmail.com>
> Subject: [GRASS-dev] grass7 on mac OSX
> To: grass-dev list <grass-dev at lists.osgeo.org>
> Message-ID: <05BC922B-8790-4579-93E3-3052D5B1518D at gmail.com>
> Content-Type: text/plain; charset=us-ascii
> Hi All,
> i upgrade grass7 from svn on mac osx 10.6.3 ,
> the build ends with an error in wxpython, rerunning make inside the wxpython director fix the problem.
I've reported this too. There is something wrong in the build/make files somewhere.
> but tring to load grass from python i had thi error :
> In [1]: from grass.lib import grass
> Traceback (most recent call last):
>  File "<ipython console>", line 1, in <module>
>  File "/Users/Shared/source/grass_trunk/dist.i386-apple-darwin10.3.0/etc/python/grass/lib/__init__.py", line 3, in <module>
>    # $Id$
>  File "/Users/Shared/source/grass_trunk/dist.i386-apple-darwin10.3.0/etc/python/grass/lib/math.py", line 7, in <module>
> ImportError: dlopen(/Applications/GRASS-7.0.app/Contents/MacOS/etc/python/grass/lib/_math.so, 2): Symbol not found: _G_math_backward_solving
>  Referenced from: /Applications/GRASS-7.0.app/Contents/MacOS/etc/python/grass/lib/_math.so
>  Expected in: /Applications/GRASS-7.0.app/Contents/MacOS/lib/libgrass_gmath.dylib
> in /Applications/GRASS-7.0.app/Contents/MacOS/etc/python/grass/lib/_math.so
> have you any clue on what i'm missing ?
> thanks!
> Massimo.
I think this is a bogus error. The identical thing happened to a student here except that it claimed to be missing the subprocess module. The module is not missing and GRASS 6.5 works fine. GRASS 7 runs fine on my Mac, but this kind of error is cropping up somewhat randomly apparently.
Michael
