[GRASS-dev] Re: [GRASS GIS] #1052: Build of 7.0.SVN dont work
GRASS GIS trac at osgeo.org
Sat May 29 06:11:34 EDT 2010
  Reporter:  jeleniste     |       Owner:  martinl
      Type:  defect        |      Status:  assigned
  Priority:  normal        |   Milestone:  7.0.0
 Component:  Packaging     |     Version:  svn-trunk
Resolution:                |    Keywords:  wingrass
  Platform:  MSWindows XP  |         Cpu:  x86-32
Comment (by martinl):
 Replying to [comment:13 glynn]:
 > Actually, I don't think that we've explicitly discussed the correct
 location for the saved $GISRC file on Windows; arguably, it should go into
 e.g. "%USERPROFILE%\Application Data\GRASS7".
 Right, currently there are two location which is quite messy approach
  * CMD - [source:grass/trunk/mswindows/GRASS-Installer.nsi at 42334#L680]
 FileWrite $0 'rem Directory where your .grass7/rc file will be
 FileWrite $0 'set HOME=%USERPROFILE%$\r$\n'
  * SH - [source:grass/trunk/mswindows/GRASS-Installer.nsi at 42334#L826]
 CreateDirectory $INSTALL_DIR\msys\home\$USERNAME\.grass7
 Unique location for config dir would nice idea.
 seems to be OK.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1052#comment:14>
