[GRASS-dev] Error on a winGRASS installer
António Rocha antonio.rocha at deimos.com.pt
Tue Nov 2 11:13:29 EDT 2010
Greetings
I'm developing an winGRASS installer. To do so, I'm following this
instructions
(http://trac.osgeo.org/grass/wiki/CompileOnWindows#CreatingaWinGRASSInstaller).
So far as I was able to create an installer, install it a visualize data
but when I try to run a scripts that uses GDALWARP I'm getting this error:
ERROR 4: Unable to open EPSG support file gcs.csv.
Try setting the GDAL_DATA environment variable to point to
the
directory containing EPSG csv files.
ERROR 1: Translating source or target SRS failed:
In the OSGEO4W wasn't getting this error so I believe that it has
something to do with the installer that I created. can anyone (I predict
that Martin Landa is the best person to answer to this) explain me what
am I missing?
Thanks
Antonio Rocha
__________ Information from ESET NOD32 Antivirus, version of virus signature database 5585 (20101102) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
