[GRASS-dev] Re: Error on a winGRASS installer
António Rocha antonio.rocha at deimos.com.pt
Tue Nov 2 13:28:47 EDT 2010
Hello Helmut
Thank you so much for your help.. It worked. As far as I was able to
test, all my scripts from OSGEO4W are working on this installer.
Thank you.
Just one last question: can I expect any problems by using mswindows
from an earlier Snapshot and my source code/compiled from older version
(early September 2010)?
Helmut Kudrnovsky wrote:
> (please keep it on the ML)
>> Hello Helmut
>> I was using source from early September. Do you think that was the problem?
> please try a fresh svn-checkout or the source-snapshot from last Saturday, because the GDAL_DATA variable etc.
> was added last week.
> best regards
> Helmut
>> Hi Antonio,
>>> ERROR 4: Unable to open EPSG support file gcs.csv.
>>> Try setting the GDAL_DATA environment variable to point to
>>> the
>>> directory containing EPSG csv files.
>>> ERROR 1: Translating source or target SRS failed:
>> some days ago I've added the GDAL_DATA variable to the nsis-installer script:
>> r44053 - grass/branches/releasebranch_6_4/mswindows
>> http://lists.osgeo.org/pipermail/grass-commit/2010-October/015000.html
>> r44054 - grass/branches/develbranch_6/mswindows
>> http://lists.osgeo.org/pipermail/grass-commit/2010-October/015001.html
>> r44055 - grass/trunk/mswindows
>> http://lists.osgeo.org/pipermail/grass-commit/2010-October/015002.html
>> please prepare the files for building the installer with a fresh svn-checkout
>> of GRASS-Packager.bat to be sure that all gdal files are included and build
>> the installer with a fresh svn-checkout of the nsis-script.
>> best regards
>> Helmut
>> ___________________________________________________________
>> GRATIS! Movie-FLAT mit über 300 Videos.
>> Jetzt freischalten unter http://movieflat.web.de
> __________ Information from ESET NOD32 Antivirus, version of virus signature database 5585 (20101102) __________
> The message was checked by ESET NOD32 Antivirus.
> http://www.eset.com
> WEB.DE DSL Doppel-Flat ab 19,99 €/mtl.! Jetzt auch mit
> gratis Notebook-Flat! http://produkte.web.de/go/DSL_Doppel_Flatrate/2
> http://www.eset.com
http://www.eset.com
