[GRASS-dev] Help - run r.profile through python
Fri Nov 5 20:33:03 EDT 2010
melolp wrote:
> grass.run_command("r.profile",-g,input= teste1,output = teste, [12244.256 -295112.597,12128.012 -295293.77])
> However I'm having the following error mesage:
> "non-keyword arg after keyword arg grass.run_command"
All arguments except the first are keyword arguments, i.e. "arg = val".
	grass.run_command(
		"r.profile",
Okay
		-g,
This should be: flags = 'g'. "-g" would be the negative of a Python
variable namd "g".
		input= teste1,
		output = teste,
Okay
This should be:
		profile = [12244.256,-295112.597,12128.012,-295293.77]
or:
		profile = [(12244.256,-295112.597),(12128.012,-295293.77)]
i.e. you need to provide the keyword, and the argument must be a valid
Python expression. run_command() etc accept lists and tuples.
