[GRASS-dev] v.in.wfs
    Paolo Cavallini
    cavallini at faunalia.it
    Thu Nov 11 13:43:08 EST 2010
Il 11/11/2010 18:31, Markus Neteler ha scritto:
> In the script there is a test if curl is installed.
> I have now added this requirement also to the manual.
Yes, but this makes the module unsuitable as a QGIS module, IMHO.
> What do you mean with "adding"? Or do you refer to the manual?
I mean, if curl is a dependency of GRASS, then it's ok. The end user
should have everything installed before running a program, not being
asked to install it during normal usage.
> ogrinfo --formats
> show the format on your system?
MMh, strange: apparently not, but http://mapserver.gdf-hannover.de is read.
All the best.
http://www.faunalia.it/pc
