[GRASS-dev] r.distance: 'maps=map1, map2' vs 'maps=map1 maps=map2'
Sat Nov 13 00:04:46 EST 2010
Maciej Sieczka wrote:
> I have discovered an undocumented feature (?) in r.distance.
> The manual reads:
> r.distance maps=map1,map2
> When I specify it as:
> r.distance maps=map1 maps=map2
> it works as well.
This is a feature of the parser, and works for all modules.
> The order can also be controlled this way. I.e.:
> r.distance maps=map1,map2 is equivalent to r.distance maps=map1 maps=map2
> and:
> r.distance maps=map2,map1 is equivalent to r.distance maps=map2 maps=map1
> Can I rely on this behavior or may it change in future? Currently it
> works for 6.4 svn and 7 svn.
It isn't expected to change. It's useful for constructing argument
lists using xargs, e.g.:
	... | sed 's/^/map=/' | xargs g.something ...
This is much harder to achieve using the opt=val,val,val,... syntax.
