[GRASS-dev] Re: [GRASS GIS] #1223: g.mapsets access from menu broken
GRASS GIS trac at osgeo.org
Thu Nov 25 03:54:28 EST 2010
 Reporter:  cmbarton   |       Owner:  grass-dev@…
     Type:  defect     |      Status:  new
 Priority:  normal     |   Milestone:  7.0.0
Component:  wxGUI      |     Version:  svn-trunk
 Keywords:             |    Platform:  MacOSX
      Cpu:  OSX/Intel  |
Changes (by martinl):
 * cc: grass-dev@… (added)
  * component:  Installation => wxGUI
Comment:
 Replying to [comment:1 cmbarton]:
 > Turns out that g.mapsets cannot be launched from the command line or
 terminal either. No way to
 g.mapsets doesn't start from the cli because all parameters are optional.
 Probably we could change this behaviour in GRASS7. You can force launching
 GUI dialog by
 g.mapsets --ui
 > set mapset access in GRASS 7 currently. Changing component from wxGUI to
 ... hmmm there is no component for general, configuration, or settings.
 I'm picking "installation" because this is slightly less erroneous than
 the other choices.
 fixed in r44412.
 Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/1223#comment:2>
