[GRASS-dev] r.sim.water in 64, 65, 7
Markus Neteler neteler at osgeo.org
Fri Nov 26 09:05:35 EST 2010
On Fri, Nov 26, 2010 at 6:12 AM, Helena Mitasova <hmitaso at unity.ncsu.edu> wrote:
> Several changes were made in r.sim.water recently but it has still some troubles on non-linux machines.
> GRASS64: it runs on linux, but gives Segmentation fault on Mac and Windows
> Glynn has fixed the segmentation fault problem in GRASS7, I believe it is r42402(?)
> http://trac.osgeo.org/grass/changeset/42402
> but the fix was not backported to GRASS6 develbranch or GRASS64, so those two do not run on Mac or Windows
I have backported r42402 to GRASS 6.5.
Please try - if it helps, we can backport to 6.4, too.
Is there another changeset to be backported?
Markus
