[GRASS-dev] Re: [GRASS GIS] #1222: v.rast.stats returns error: global name 'vector' is not defined
GRASS GIS trac at osgeo.org
Sat Nov 27 03:16:54 EST 2010
 Reporter:  akbgf         |       Owner:  grass-dev@…
     Type:  defect        |      Status:  new
 Priority:  normal        |   Milestone:  7.0.0
Component:  Vector        |     Version:  unspecified
 Keywords:  v.rast.stats  |    Platform:  Linux
      Cpu:  x86-32        |
Comment(by mmetz):
 I have made some more changes:
 * input vector key changed to vector, as in 6.x
 * the temporary region is now aligned to the raster instead of just
 setting the region resolution to the raster, avoiding grid shifts and
 slightly inaccurate results
 * -nan is now converted to NULL and not left as -nan (-nan can sometimes
 occur)
 * the table key column is no longer hardcoded to cat, instead the actual
 table key column is used
 * speed up by using the zonal functionality of r.univar (number of
 categories times faster)
 Markus M
Ticket URL: <https://trac.osgeo.org/grass/ticket/1222#comment:2>
