[GRASS-dev] Re: after compiling GRASS ,
sunil sunilrajkiran at gmail.com
Fri Oct 1 03:53:51 EDT 2010
thank you all
i have correctly rectified all the GRASS errors with all your help
i have installed python,sip,QT, while configure PyQT in windows terminal
it gives a window  error like
  cannot start qtdirs.exe because mingwm30.dll not found , can you give a
View this message in context: http://osgeo-org.1803224.n2.nabble.com/after-compiling-GRASS-tp5586650p5590475.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
