[GRASS-dev] Re: [GRASS GIS] #1161: g.region and r.info decimel issue when using grass python libs
GRASS GIS trac at osgeo.org
Sun Oct 3 18:15:12 EDT 2010
  Reporter:  isaacullah  |       Owner:  grass-dev@…
      Type:  defect      |      Status:  closed
  Priority:  normal      |   Milestone:  6.4.1
 Component:  Python      |     Version:  6.4.0
Resolution:  invalid     |    Keywords:
  Platform:  All         |         Cpu:  All
Comment(by cmbarton):
 Thanks again. We can follow this to ensure the matches within Java. I just
 wondered if this would be better accomplished within grass.region(). This
 returns a dictionary (seen in our original post). I can't say exactly
 where the lossy conversion is happening--going into the dictionary, coming
 out of the dictionary, or at some other point. It's clear from your
 explanation that the representation of these values can change at various
 places. This all makes sense. But still most users would expect
 grass.run_command('g.region', flags='gp') and grass.region() to give the
 same results.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1161#comment:7>
