[GRASS-dev] Re: [GRASS GIS] #1161: g.region and r.info decimal issue when using grass python libs
GRASS GIS trac at osgeo.org
Sun Oct 3 21:18:35 EDT 2010
  Reporter:  isaacullah  |       Owner:  grass-dev@…
      Type:  defect      |      Status:  closed
  Priority:  normal      |   Milestone:  6.4.1
 Component:  Python      |     Version:  6.4.0
Resolution:  invalid     |    Keywords:  g.region, precision
  Platform:  All         |         Cpu:  All
Changes (by hamish):
  * keywords:  => g.region, precision
Comment:
 Replying to [comment:8 hamish]:
 > I guess what I find weird is that g.region will never report
 > with precision > .15g, which is exactly representable
 well, no, as in the "5.1" example. but reproducible anyhow..
 > & will never saturate the double-prec bitspace, and so the python
 > repr() example above is perhaps using %.16f internally?
 anyway, if it matters python's "print" gives it back to you in the form
 you were expecting,
 >>> n = 4293588.60267
 >>> n
 4293588.6026699999
 >>> print n
 4293588.60267
 Hamish
 ps- do you mind if I move LandDyn/ in addons svn to raster/LandDyn?
Ticket URL: <https://trac.osgeo.org/grass/ticket/1161#comment:10>
