[GRASS-dev] Re: [GRASS GIS] #1161: g.region and r.info decimal issue when using grass python libs
Isaac Ullah isaac.ullah at asu.edu
Sun Oct 3 22:49:09 EDT 2010
Yes it is fine to move them. I suppose that after the move my current paths
in subcommander will be broken? If so am I correct in assuming that to get
everything working again I will need to check them out freshly from
subversion, and make a new local copy?
Cheers,
Isaac
>  Reporter:  isaacullah  |       Owner:  grass-dev@…
>      Type:  defect      |      Status:  closed
>  Priority:  normal      |   Milestone:  6.4.1
>  Component:  Python      |     Version:  6.4.0
> Resolution:  invalid     |    Keywords:  g.region, precision
>  Platform:  All         |         Cpu:  All
> Changes (by cmbarton):
>  * cc: cmbarton (added)
> Comment:
>  Replying to [comment:10 hamish]:
>  > Replying to [comment:8 hamish]:
>  > > I guess what I find weird is that g.region will never report
>  > > with precision > .15g, which is exactly representable
>  > well, no, as in the "5.1" example. but reproducible anyhow..
>  > > & will never saturate the double-prec bitspace, and so the python
>  > > repr() example above is perhaps using %.16f internally?
>  > anyway, if it matters python's "print" gives it back to you in the form
>  you were expecting,
>  > >>> n = 4293588.60267
>  > >>> n
>  > 4293588.6026699999
>  > >>> print n
>  > 4293588.60267
>  > Hamish
>  > ps- do you mind if I move LandDyn/ in addons svn to raster/LandDyn?
>  That's fine. But we need to copy Isaac, as he is maintaining this.
>  Michael
> Ticket URL: <https://trac.osgeo.org/grass/ticket/1161#comment:11>
> GRASS GIS <http://grass.osgeo.org>
Isaac I Ullah, M.A.
Archaeology PhD Candidate,
ASU School of Evolution and Social Change
Research Assistant,
Mediterranean Landscape Dynamics Project
ullah at archaeologist.com
http://www.public.asu.edu/~iullah
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20101003/315f327c/attachment.html
