[GRASS-dev] Re: [GRASS GIS] #1189: wingrass: 'g.region -l' fails
GRASS GIS trac at osgeo.org
Wed Oct 6 05:27:37 EDT 2010
 Reporter:  hamish     |       Owner:  grass-dev@…
     Type:  defect     |      Status:  new
 Priority:  critical   |   Milestone:  6.4.1
Component:  Packaging  |     Version:  svn-develbranch6
 Keywords:  g.region   |    Platform:  MSWindows XP
      Cpu:  x86-32     |
Comment(by neteler):
 I had reported this to PROJ as
 http://trac.osgeo.org/proj/ticket/81
 FrankW has identified the problem (which only occurred for him when
 proj_def.dat could
 not be found) and fixed it (http://trac.osgeo.org/proj/changeset/1914).
 All this
 happened only in proj-trunk.
 I can confirm that this problem has been solved for at least Linux but I
 assume
 that the solution is general.
 Markus
Ticket URL: <https://trac.osgeo.org/grass/ticket/1189#comment:1>
