[GRASS-dev] [GRASS GIS] #1193: Python Menu: Japanese (double byte character) in menu may cause parser error.
GRASS GIS trac at osgeo.org
Fri Oct 8 04:40:34 EDT 2010
error.
 Reporter:  naokiueda    |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  major        |   Milestone:  6.4.1
Component:  Python       |     Version:  6.4.0
 Keywords:               |    Platform:  MSWindows 7
      Cpu:  Unspecified  |
 In Japanese environment, r.reclass from menu GUI does not launched.
 It is because Japanese character is double byte, and if first byte or
 second bite is same code as '<', '>', or maybe '\', it cause parser error.
 One of same trouble has been solved by following, but it looks like other
 problem (caused by same mechanism) still remain.
 GRASS in OSGEO4W, it is fix
 in File menuform.py rev.43275 Line 1280
         # parse the interface decription
         self.grass_task = grassTask()
         handler = processTask(self.grass_task)
         enc = locale.getdefaultlocale()[1]
         if enc and enc.lower() not in ("utf8", "utf-8"):
 xml.sax.parseString(getInterfaceDescription(cmd[0]).decode(enc).split('\n',1)[1].replace('',
 '<?xml version="1.0" encoding="utf-8"?>\n', 1).encode("utf-8"),
                             handler)
         else:
             xml.sax.parseString(getInterfaceDescription(cmd[0]),
                             handler)
 Verion
 GRASS 6.4.0 (2010)
 Revision: 37101
 Date: 2009-05-10 13:35:38 +0200 (So, 10 Mai 2009)
 (Fri Oct 08 17:30:18 2010) コマンド終了 (0 sec)
 Error Log
   File "C:/GRASS__6401/etc/wxpython/wxgui.py", line 540, in
 OnMenuCmd
 cmd = self.GetMenuCmd(event)
   File "C:/GRASS__6401/etc/wxpython/wxgui.py", line 527, in
 GetMenuCmd
 input =
 menuform.GUI().GetCommandInputMapParamKey(cmdlist[0])
   File
 "C:\GRASS__6401\etc\wxpython\gui_modules\menuform.py", line
 1944, in GetCommandInputMapParamKey
 xml.sax.parseString(getInterfaceDescription(cmd), handler)
   File "C:\OSGeo4W\apps\Python25\lib\xml\sax\__init__.py",
 line 49, in parseString
 parser.parse(inpsrc)
   File
 "C:\OSGeo4W\apps\Python25\lib\xml\sax\expatreader.py", line
 107, in parse
 xmlreader.IncrementalParser.parse(self, source)
   File "C:\OSGeo4W\apps\Python25\lib\xml\sax\xmlreader.py",
 line 123, in parse
 self.feed(buffer)
   File
 211, in feed
 self._err_handler.fatalError(exc)
   File "C:\OSGeo4W\apps\Python25\lib\xml\sax\handler.py",
 line 38, in fatalError
 raise exception
 xml.sax._exceptions
 SAXParseException
 <unknown>:1:30: unknown encoding
 Also, when I download source file, it's encoding is ascii (Shift-JIS, for
 japanese) and not UTF-8. I think source file should be in UTF-8.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1193>
