[GRASS-dev] Re: [GRASS GIS] #1191: make install gives sed error in r43810
GRASS GIS trac at osgeo.org
Mon Oct 11 13:29:43 EDT 2010
  Reporter:  cgsbob        |       Owner:  grass-dev@…
      Type:  defect        |      Status:  reopened
  Priority:  normal        |   Milestone:  6.5.0
 Component:  Installation  |     Version:  svn-develbranch6
Resolution:                |    Keywords:  Makefile
  Platform:  All           |         Cpu:  All
Comment(by hellik):
 Replying to [comment:8 hamish]:
 > Replying to [comment:7 hellik]:
 > > maybe related?
 > > tested with r43842 in the osgeo4w-build-environment.
 > > compilation ok, but installing isn't
 > yes, it's related. 'sed -i' isn't present in MSys. Pity, as it's really
 very handy. FWIW it isn't strictly part of the standard but MacOSX does
 have it. MSys is using's GNU's version of it, I guess they removed it
 because Windows is much more picky about what you can do with an open
 file. ?
 > hopefully fixed in r43854.
 not really
 GRASS GIS compilation log
 Started compilation: Mon Oct 11 15:36:04 GMT 2010
 Errors in:
 No errors detected.
 Finished compilation: Mon Oct 11 17:11:23 GMT 2010
 Mon Oct 11 17:11:23 GMT 2010: STARTING make install
 include/Make/Doxygen.make:13: warning: overriding commands for target
 `htmldocs                                         -single'
 include/Make/Docs.make:11: warning: ignoring old commands for target
 `htmldocs-                                         single'
 include/Make/Doxygen.make:19: warning: overriding commands for target
 `htmldocs                                         '
 include/Make/Docs.make:38: warning: ignoring old commands for target
 `htmldocs'
 include/Make/Doxygen.make:39: warning: overriding commands for target
 `pdfdocs'
 include/Make/Docs.make:49: warning: ignoring old commands for target
 `pdfdocs'
 include/Make/Doxygen.make:51: warning: overriding commands for target
 `cleandoc                                         s'
 include/Make/Docs.make:55: warning: ignoring old commands for target
 `cleandocs                                         '
 echo /c/osgeo4w/usr/src/grass6_devel/bin.i686-pc-mingw32/grass65
 `htmldocs                                         -single'
 `htmldocs-                                         single'make[1]:
 Entering directory `/c/osgeo4w/usr/src/grass6_devel'
 `htmldocs                                         '
 `htmldocs'
 `pdfdocs'
 `pdfdocs'
 `cleandoc                                         s'
 `cleandocs                                         '
 test -d /c/OSGeo4W/apps/grass/grass-6.5.svn || mkdir -p -m 755
 /c/OSGeo4W/apps/
 grass/grass-6.5.svn
 test -d /c/OSGeo4W/bin/bin || mkdir -p -m 755 /c/OSGeo4W/bin/bin
 sed -e "s#^GISBASE.*#GISBASE=/c/OSGeo4W/apps/grass/grass-6.5.svn#"
 /c/osgeo4w/u
 sr/src/grass6_devel/bin.i686-pc-mingw32/grass65 >
 /c/OSGeo4W/bin/bin/grass65
 chmod a+x /c/OSGeo4W/bin/bin/grass65
 sed -e "s#WINGISBASE=.*#WINGISBASE=/c/OSGeo4W/apps/grass/grass-6.5.svn#"
 /c/osg
 eo4w/usr/src/grass6_devel/bin.i686-pc-mingw32/grass65.bat >
 /c/OSGeo4W/bin/bin/                                         grass65.bat
 chmod a+x /c/OSGeo4W/bin/bin/grass65.bat
 cd /c/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32 ; tar cBf -
 AUTHORS COP                                         YING CHANGES
 REQUIREMENTS.html GPL.TXT contributors.csv translators.csv | (cd /
 c/OSGeo4W/apps/grass/grass-6.5.svn ; tar xBf - ) 2>/dev/null
 cd /c/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32 ; tar cBf - bin |
 (cd /
 bwidget | (                                         cd
 /c/OSGeo4W/apps/grass/grass-6.5.svn ; tar xBf - ) 2>/dev/null
 cd /c/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32 ; tar cBf - docs |
 (cd
 cd /c/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32 ; tar cBf - driver
 | (c                                         d
 cd /c/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32 ; tar cBf - etc |
 (cd /
 cd /c/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32 ; tar cBf - fonts
 | (cd
 cd /c/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32 ; tar cBf - man |
 (cd /
 tar: man: Cannot stat: No such file or directory
 tar: Error exit delayed from previous errors
 scripts | (                                         cd
 cd /c/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32 ; tar cBf - tools
 | (cd
 if [ 1 -eq 1 ] ; then cd /c/osgeo4w/usr/src/grass6_devel/dist.i686-pc-
 mingw32 ;                                          tar cBf - locale | (cd
 v/null ; fi
 include | (                                         cd
 sed -e "s#^\(GRASS_HOME.[^=]*\).*#\1=
 /c/OSGeo4W/apps/grass/grass-6.5.svn#" -e
 "s#^\(RUN_GISBASE.[^=]*\).*#\1= /c/OSGeo4W/apps/grass/grass-6.5.svn#"
 /c/osgeo4
 w/usr/src/grass6_devel/dist.i686-pc-mingw32/include/Make/Platform.make >
 /c/OSG
 eo4W/apps/grass/grass-6.5.svn/include/Make/Platform.make
 sed -e 's#/tools/g.html2man/g.html2man#/tools/g.html2man#'
 rass6_devel/dist.i686-pc-mingw32/include/Make/Man.make >
 grass-6.5.svn/include/Make/Man.make
 cd /c/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32 ; tar cBf - lib |
 (cd /
 sed 's#'/c/osgeo4w/usr/src/grass6_devel/dist.i686-pc-
 mingw32'#'/c/OSGeo4W/apps/
 grass/grass-6.5.svn'#g' /c/osgeo4w/usr/src/grass6_devel/dist.i686-pc-
 mingw32/et                                         c/monitorcap >
 /c/OSGeo4W/apps/grass/grass-6.5.svn/etc/monitorcap
 mingw32/et                                         c/fontcap >
 /c/OSGeo4W/apps/grass/grass-6.5.svn/etc/fontcap
 chmod -R a+rX /c/OSGeo4W/apps/grass/grass-6.5.svn 2>/dev/null
 tar cBf - gem/skeleton | (cd /c/OSGeo4W/apps/grass/grass-6.5.svn/etc ; tar
 xBf                                          - ) 2>/dev/null
 tar: gem/skeleton/.svn/text-base: file changed as we read it
 tar: gem/skeleton/.svn/tmp: file changed as we read it
 tar: gem/skeleton/.svn: file changed as we read it
 tar: gem/skeleton: file changed as we read it
 /bin/install -c  gem/gem65 /c/OSGeo4W/bin/bin 2>/dev/null
 make[1]: [real-install] Error 1 (ignored)
 make[1]: Leaving directory `/c/osgeo4w/usr/src/grass6_devel'
 Mon Oct 11 17:12:54 GMT 2010: STARTING cleanup
 sed: can't read /c/OSGeo4W/apps/grass/bin/grass65: No such file or
 directory
 in C:\OSGeo4W\usr\src\grass6_devel\bin.i686-pc-mingw32 there are shell-
 script and bat-file, but in C:\OSGeo4W\apps\grass\bin there is again only
 grass65.tmpl
 best regards
 Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1191#comment:9>
