[GRASS-dev] [GRASS GIS] #1196: v.krige.py fails with ImportError: No module named vkrige
GRASS GIS trac at osgeo.org
Thu Oct 14 05:32:17 EDT 2010
 Reporter:  marisn  |       Owner:  grass-dev@…
     Type:  defect  |      Status:  new
 Priority:  normal  |   Milestone:  6.5.0
Component:  Vector  |     Version:  svn-develbranch6
 Keywords:          |    Platform:  Linux
      Cpu:  x86-64  |
 GRASS 6.5 r43904
 GRASS 6.5.svn (personal_spearfish_60):~/soft/grass6_devel > v.krige.py
 Loading packages, please wait...
 Loading required package: sp
 Loading required package: rgdal
 Geospatial Data Abstraction Library extensions to R successfully loaded
 Loaded GDAL runtime: GDAL 1.7.2, released 2010/04/23
 Path to GDAL shared files: /usr/share/gdal
 Loaded PROJ.4 runtime: Rel. 4.7.1, 23 September 2009
 Path to PROJ.4 shared files: (autodetected)
 Loading required package: XML
 GRASS GIS interface loaded with GRASS version: 6.5.svn
 and location: personal_spearfish_60
 Loading required package: foreign
 Loading required package: lattice
         Note: polygon geometry computations in maptools
         depend on the package gpclib, which has a
         restricted licence. It is disabled by default;
         to enable gpclib, type gpclibPermit()
 Checking rgeos availability as gpclib substitute:
 FALSE
   File "/home/maris/soft/grass6_devel/dist.x86_64-unknown-linux-
 gnu/scripts/v.krige.py", line 422, in <module>
     main()
 gnu/scripts/v.krige.py", line 312, in main
     import vkrige as GUI
Ticket URL: <http://trac.osgeo.org/grass/ticket/1196>
