[GRASS-dev] How to get stop a script with an error in a function
Fri Oct 15 10:23:05 EDT 2010
António Rocha wrote:
> I have built a Py Script that is similar to r.in.aster, I mean, to
> reproject/project a file and then import into grass.
> The problem is when I select a non raster file. A get an error in
> GDALWARP but the script continue.
> And then it calls r.in.gdal to import and then I get ERROR 4. What I
> want is a way to "stop" the process (with grass_fatal) when I get ERROR 4.
> Is this possible? can anyone give me a tip? Some approach to get the
> error. I have tried with try: except: but it didn't work out
Check the exit code from the command. Commands should use a non-zero
exit code if there was an error.
It would help to know exactly how the command is being run.
