[GRASS-dev] How to get stop a script with an error in a function
António Rocha antonio.rocha at deimos.com.pt
Fri Oct 15 10:55:14 EDT 2010
*Glynn Clements* wrote:
> Check the exit code from the command. Commands should use a non-zero
> exit code if there was an error.
> It would help to know exactly how the command is being run.
You are absolutely right :)
Among others, I'm using:
grass.run_command("r.in.gdal", flags= 'k', overwrite = 'o', input =
src_file, output = target_file)
Shall I do something like
check_process=grass.run_command("r.in.gdal", flags= 'k', overwrite =
'o', input = src_file, output = target_file)
if check_process=0:
   gdal_fatal (_("ERROR"))
Thanks
Antonio
__________ Information from ESET NOD32 Antivirus, version of virus signature database 5534 (20101015) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
