[GRASS-dev] Re: [GRASS GIS] #1194: v.build opt=dump does not report the Z coord
GRASS GIS trac at osgeo.org
Fri Oct 15 11:53:19 EDT 2010
  Reporter:  msieczka  |       Owner:  martinl
      Type:  defect    |      Status:  closed
  Priority:  normal    |   Milestone:  6.4.1
 Component:  Vector    |     Version:  svn-releasebranch64
Resolution:  fixed     |    Keywords:  v.build, 3D
  Platform:  All       |         Cpu:  All
Changes (by msieczka):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Replying to [comment:2 martinl]:
 > Try r43897 (backported to 6.5 for testing)
 Looks OK:
 GRASS 6.5.svn (spearfish60):~ > v.build opt=dump map=v3d
 ---------- TOPOLOGY DUMP ----------
 N,S,E,W,T,B: 4927312.491377, 4927312.491377, 601940.330289, 601940.330289,
 2.173792, 2.173792
 Nodes (1 nodes, alive + dead ):
 node = 1, n_lines = 1, xyz = 601940.330289, 4927312.491377, 2.173792
   line =   1, type = 1, angle = -9.000000
 Lines (1 lines, alive + dead ):
 line = 1, type = 1, offset = 14 n1 = 1, n2 = 1, left/area = 0, right = 0
 2.173792, 2.173792
 Areas (0 areas, alive + dead ):
 Islands (0 islands, alive + dead ):
 Thanks!
Ticket URL: <https://trac.osgeo.org/grass/ticket/1194#comment:3>
