[GRASS-dev] Re: GRASS-dev] grass fails to detect wxpython version
Michael Barton Michael.Barton at asu.edu
Fri Oct 15 13:31:02 EDT 2010
OK. Thanks for the update.
Michael
______________________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
Tempe, AZ  85287-2402
USA
voice: 	480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax:          480-965-7671(SHESC), 480-727-0709 (CSDC)
www: 	http://csdc.asu.edu, http://shesc.asu.edu
		http://www.public.asu.edu/~cmbarton
On Oct 15, 2010, at 10:08 AM, Massimo Di Stefano wrote:
> Yes i'm aware about it,
> the problem is that i'm using a custom built python.framework (i386, x86_64)
> the WxPyhon-2.8.11.dmg don't works with 64-bit (where i have all the other python modules installed)
> btw, i started to debug the wxgrass-problems with the WxPython-2.9 pre-release
> i found some bugs and fixed some problems in the code.
> now without comment any lines in wxgrass i have the gui start ... but don't works yet
> we found a bug in the wx-prerelease, i opened a tiket :
> http://trac.wxwidgets.org/ticket/12569
> i subscribed myself to both WxPython-Mac amd -Dev list, i hope it will fixed soon.
> btw my system python works fine with the wx preinstalled on snow leopard
> ... i'm only tring to avoid to duplicate my python environment ..
> so it isn't a blocking issue.
> Massimo.
> Il giorno 15/ott/2010, alle ore 17.18, Michael Barton ha scritto:
>> Massimo,
>> At the moment, I'm too tied up to be able to do much. But I did just install a new wxPython and noticed that you can get a binary for 2.8.10.11 that supports Python 2.7 now.
>> Michael
>> C. Michael Barton
>> fax:          480-965-7671 (SHESC),  480-727-0709 (CSDC)
>> www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
>> On Oct 15, 2010, at 1:07 AM, Massimo Di Stefano wrote:
>>> Hi,
>>> Michael, yes it is not backward compatible,
>>> i have commented out some lines in 4 different files in the gui source,
>>> globarcar.py (lines 41,42,61,62)
>>> wxgui.py (line 112)
>>> ghelp.py (line 103)
>>> mapdisp.py (line 132)
>>> now the gui start but is not usable due to the commented code.
>>> Generally i can see the code lines where we set an icon file, is no longer working on wx 2.9.
>>> On osx snow leopard the lack of cocoa support from wx 2.8 is a bad problem
>>> .. actually i'm using python2.7 (i386 + x86_64)
>>> and no wx 2.8 binay are avaiable ... so i had to stay on tcltk
>>> (or using a custom gui i'm working on, done in pyqt but is pretty immature yet)
>>> i tried the wx2.9 snapshot demos and it works pretty fine, seems 2.9 is near to be mature.
>>> i can give you my time offering support to build and test grass gui using wx2.9
>>> and providing logs and tentative of debug.... but unlucky i've not a good knowledge of wxgrass and wx itself.
>>> Please let me know if make sense for you and what do you think about.
>>> maybe is the case to switch this discussion to the gui mailing list?
>>> thanks a lot!
>>> Massimo.
>>> Il giorno 15/ott/2010, alle ore 09.23, Michael Barton ha scritto:
>>>> OK. Keep us posted. I'm concerned that wxPython 2.9 is not backward compatible.
>>>> Michael
