[GRASS-dev] bilinear and bicubic raster interpolation
Markus Neteler neteler at osgeo.org
Sun Oct 17 11:45:46 EDT 2010
On Sun, Oct 17, 2010 at 11:40 AM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> Glynn Clements wrote:
>> However, there is another issue with r.proj (7.0) and r.proj.seg
>> (6.x): bilinear and cubic interpolation give a small number of garbage
>> results due to incorrect use of the caching mechanism (blocks are
>> being replaced while references remain). I'll fix this shortly.
> This should be fixed by r43944.
The common backport question comes up for this one and r43943...
Indications welcome.
Markus
