[GRASS-dev] Re: Error when running a scrip in Windows-WinGRASS
Markus Neteler neteler at osgeo.org
Sun Oct 17 12:43:56 EDT 2010
On Mon, Oct 11, 2010 at 1:29 PM, Helena Herrera
<helenaherrera1980 at gmail.com> wrote:
> Hi
>> If I understand Glynn's comments correctly it won't work through the main
>> build system, but for personal add-on scripts that's not the end of the
>> world.
> That is exacly what I want. I have my winGRASS6.4 installation and I want to
> run/use some Python scripts. Just that...
>> the important things is that both the script and python.exe can be found
>> in the path. You'll probably need to give your script a .py extension, and
>> make sure that Windows associates .py with Python and knows to run them
>> with python.exe. A web search will show a number of hits on how to do
>> that,
>> and there's a number of mostly untested attempts at it deep within the
>> mswindows/ package installer scripts in the grass source code.
> I have browsed but I really didn't find anyone attempting having a python
> script in winGRASS6.4.
>> If the .py filename extension stuff fails, maybe you could write a custom
>> .bat file which launches "python your_script.py", something similar to
>> what
>> is done for the UNIX shell scripts that ship with WinGrass 6.x.
> YOu mean (e.g. my Script is called i.test.py
> I should have a i.test.bat in bin folder and with the following?
> @"%GRASS_SH%" -c '"%GISBASE%/scripts/i.test.py" %*'
> How can I know if ther python is in the path?
Helena, did you check here?
http://grass.osgeo.org/wiki/GRASS_and_Python#MS-Windows
Markus
