[GRASS-dev] Re: [GRASS-user] Error when importing data in Windows with Python Script
Mon Oct 18 09:24:02 EDT 2010
Luis Lisboa wrote:
> > No, but wxGUI's "command prompt" is using shlex.split(), which mimics
> > a typical Unix shell:
> >        >>> shlex.split(r'C:\Data\L5216065_06520070405_B70.TIF')
> >        ['C:DataL5216065_06520070405_B70.TIF']
> > I suspect that it should have "posix = False" on Windows:
> >        >>> shlex.split(r'C:\Data\L5216065_06520070405_B70.TIF', posix =
> > False)
> >        ['C:\\Data\\L5216065_06520070405_B70.TIF']
> About this, What can i do to fix this? Or isn't anything I can do?
I suggest filing a bug report via http://trac.osgeo.org/grass/
In terms of a fix ... in gui_modules/utils.py, add:
	import shlex
	def split(s):
	    return shlex.split(s, posix = (sys.platform != "win32"))
The tricky part is deciding which occurrences of shlex.split() should
be replaced. It's possible that some of them need to retain the POSIX
syntax conventions (where a backslash quotes the following character).
I suspect that those in prompt.py should be changed, but I'm not sure
about the others.
