[GRASS-dev] bilinear and bicubic raster interpolation
Hamish hamish_b at yahoo.com
Mon Oct 18 15:13:31 EDT 2010
> > until bugs in the new versions are fixed, I'd vote to leave
> > these two in place:
> > vector/v.buffer/DEPRECATED
> > vector/v.parallel/DEPRECATED
> That only helps people who build from source.
> If there are problems with the new versions, perhaps the old
> versions should be built as well?
I don't think that's needed, and anyone using it for comparison
& able to do anything about it would be building from source
anyway. ie I mean to use the old version as a delta, not a
fallback. or moreover, I'm not sure if the old version would
semi-offline for a while,
