[GRASS-dev] C rotine- parsing all image into a variable
António Rocha
antonio.rocha at deimos.com.pt
Wed Oct 20 11:20:34 EDT 2010
Hello Morits
Thanks for the feedback. My problem is not a segmentation issue but a
memory-allocation issue. I need to understand how in GRASS (C functions)
I can allocate all pixels of a group images to an matrix (array of
array) instead of just row-by-row (or column-by-column).
Does anyone has a clue?
Thanks
Antonio Rocha
Moritz Lennert wrote:
> On Wed, October 20, 2010 10:13, António Rocha wrote:
>> Greetings
>> I'm developing a GRASS C rotine to perform segmentation of images. As
>> far as I can see, rotines like i.gensig and i.maxlik (or even r.example)
>> usually gets a row and tthen process cell-by-cell. In this case, instead
>> of loading only a row per image, I want to parse to the variable all the
>> image. What C function shall I use?
> Don't have a direct answer, but have you looked at i.smap which also uses
> some form of segmentation.
> Moritz
> __________ Information from ESET NOD32 Antivirus, version of virus signature database 5548 (20101020) __________
> The message was checked by ESET NOD32 Antivirus.
> http://www.eset.com
http://www.eset.com
