[GRASS-dev] g.mapsets in G7
Markus Neteler neteler at osgeo.org
Sun Oct 24 05:43:29 EDT 2010
On Sun, Oct 24, 2010 at 10:03 AM, Martin Landa <landa.martin at gmail.com> wrote:
> Hi,
> I would like to change the interface of g.mapsets in G7. Currently
> there are separate parameters to add, remove and set mapsets from
> search path. My suggestions is to have only two parameters:
> mapsets - List of mapsets to add/remove/set
> option - add/remove/set
It is debatable if that's better or more complex - in any case then the same
concept should be adopted also for other modules where stuff is added or
removed (categories, columns etc) - for CLI consistency
Markus
