[GRASS-dev] Re: [GRASS GIS] #1178: WinGrass: g.extension - problem with path to $GISBASE
GRASS GIS trac at osgeo.org
Tue Oct 26 12:40:04 EDT 2010
 Reporter:  hellik                                             |       Owner:  grass-dev@…
     Type:  defect                                             |      Status:  new
 Priority:  major                                              |   Milestone:  6.4.1
Component:  Installation                                       |     Version:  svn-releasebranch64
 Keywords:  wingrass, g.extension, path, installation, addons  |    Platform:  MSWindows Vista
      Cpu:  x86-32                                             |
Comment(by hellik):
 Replying to [comment:22 hellik]:
 > Replying to [comment:19 hamish]:
 > > Should we (can we?) rewrite that file each time at program startup to
 reflect the current shortname version of the path?
 > a possible example from the osgeo4w-commandline-starting-script for
 getting dynamically the current path:
 > @echo off
 > rem Root OSGEO4W home dir to the same directory this script exists in
 > set OSGEO4W_ROOT=%~dp0
 > rem Remove trailing backslash
 > set OSGEO4W_ROOT=%OSGEO4W_ROOT:~0,-1%
 > Helmut
 FYI instead of the installation path in windows written in the startup-
 script grass64svn.bat by the nsis-installer once during installation:
 (http://trac.osgeo.org/grass/browser/grass/branches/releasebranch_6_4/mswindows
 /GRASS-Installer.nsi#L645)
 for example
 rem Set GRASS Installation Directory Variable
 set GRASSDIR=C:\Program Files\GRASS-64-SVN
 I've tried following in the startup-script grass64svn.bat
 set GRASSDIR=%~dps0
 set GRASSDIR=%GRASSDIR:~0,-1%
 the installation path is expanded in the short form without a trailing
 backslash.
 wingrass64 is starting and working normally.
 so maybe this way of getting the shortform of the installation path could
 help for ''make'' used by g.extension (maybe also for the +nadgrids-
 problem with spaces in path, ...)?
 Helmut
 p.s. any idea about http://trac.osgeo.org/grass/ticket/1103 (releasing the
 windows command line)
Ticket URL: <http://trac.osgeo.org/grass/ticket/1178#comment:23>
