[GRASS-dev] Re: [GRASS GIS] #1158: g.mremove fails when used with wildcard in WinGRASS-6.4.0-1
GRASS GIS trac at osgeo.org
Thu Oct 28 05:40:23 EDT 2010
 Reporter:  lponti                |       Owner:  grass-dev@…
     Type:  defect                |      Status:  new
 Priority:  normal                |   Milestone:  6.4.1
Component:  Vector                |     Version:  6.4.0
 Keywords:  g.mremove, wildcards  |    Platform:  MSWindows 7
      Cpu:  x86-32                |
Comment(by lponti):
 Still having the same issue using recent svn snapshopts: g.mremove needs
 to be run twice when used with wildcards to remove vectors.
 I have g.mremove in a cleanup routine inside a bash script
 cleanup()
         # Remove temp directory.
         \rm -rf $DIRTMP
         # Remove temp text files.
         \rm -f ~/clipRegion.txt
         # Remove gis temp files in latlong location
         g.mremove -f vect=map*
 Currently using GRASS from installer WinGRASS-6.4.SVN-r43880-1-Setup.exe
 Any hints appreciated. Thanks and regards,
 Luigi
Ticket URL: <http://trac.osgeo.org/grass/ticket/1158#comment:8>
