[GRASS-dev] Re: [GRASS-user] Catch errors from grass.mapcalc
Martin Landa landa.martin at gmail.com
Sat Oct 30 04:56:23 EDT 2010
2010/10/30 Glynn Clements <glynn at gclements.plus.com>:
> Beyond that, we should probably think about how to deal with errors in
> the Python scripting library. I.e. whether to raise Python exceptions,
> return status codes, call fatal(), etc. Right now, each function does
> as it pleases; there isn't any consistency.
r44086 helps a bit?
error() raise ScriptException() by default. If you call
raise_on_error(False) then error() prints error message via `g.message
-e`.
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
