[GRASS-dev] [GRASS GIS] #1207: wingrass - installation incomplete/messed
GRASS GIS trac at osgeo.org
Sat Oct 30 17:20:14 EDT 2010
 Reporter:  hellik               |       Owner:  grass-dev@…
     Type:  defect               |      Status:  new
 Priority:  normal               |   Milestone:  6.4.1
Component:  Installation         |     Version:  svn-releasebranch64
 Keywords:  wingrass, compiling  |    Platform:  MSWindows Vista
      Cpu:  x86-32               |
 fresh svn-checkout of releasebranch64
 compiled and installed in the osgeo4w-tree (source is in
 C:\OSGeo4W\usr\src\grass64svn) by package.sh in the source
 http://trac.osgeo.org/grass/browser/grass/branches/releasebranch_6_4/mswindows/osgeo4w/package.sh
 #!/c/OSGeo4W/apps/msys/bin/sh
 set -e
 if ! [ -d mswindows ]; then
         echo Start from GRASS toplevel dir
         exit 1
 fi
 export OSGEO4W_ROOT_MSYS=/c/OSGeo4W
 export
 PATH=.:/c/mingw/bin:/usr/local/bin:/bin:$OSGEO4W_ROOT_MSYS/bin:/c/WINDOWS/system32:/c/WINDOWS:/c/WINDOWS/System32/Wbem
 version() {
                 read MAJOR
                 read MINOR
                 read PATCH
                 echo $MAJOR.$MINOR.$PATCH
         ) <include/VERSION
 export VERSION=$(version)
 export PACKAGE=3
 echo
 echo
 echo
 if ! [ -f mswindows/osgeo4w/configure-stamp ]; then
         if [ -e include/Make/Grass.make ] ; then
             echo $(date): STARTING make distclean
             make distclean
         fi
         echo $(date): STARTING configure
         ./configure \
                 --with-libs="$OSGEO4W_ROOT_MSYS/apps/gdal-16/lib
 $OSGEO4W_ROOT_MSYS/lib" \
                 --with-includes="$OSGEO4W_ROOT_MSYS/apps/gdal-16/include
 $OSGEO4W_ROOT_MSYS/include" \
                 --exec-prefix=$OSGEO4W_ROOT_MSYS/bin \
                 --libexecdir=$OSGEO4W_ROOT_MSYS/bin \
                 --prefix=$OSGEO4W_ROOT_MSYS/apps/grass \
                 --includedir=$OSGEO4W_ROOT_MSYS/include \
                 --disable-x --without-x \
                 --with-cxx \
                 --enable-shared \
                 --enable-largefile \
                 --with-opengl=windows \
                 --with-fftw \
                 --with-freetype \
                 --with-proj-share=$OSGEO4W_ROOT_MSYS/share/proj \
                 --with-gdal=$OSGEO4W_ROOT_MSYS/bin/gdal-config \
                 --with-tcltk \
                 --with-sqlite \
                 --with-postgres \
                 --with-curses \
                 --with-regex \
                 --with-nls \
                 --with-freetype-
 includes=$OSGEO4W_ROOT_MSYS/include/freetype2 \
                 --with-odbc
         touch mswindows/osgeo4w/configure-stamp
 fi
 make || make
 echo $(date): STARTING make install
 make install
 echo $(date): STARTING cleanup
 mv $OSGEO4W_ROOT_MSYS/apps/grass/grass-$VERSION/lib/*.$VERSION.dll
 rm $OSGEO4W_ROOT_MSYS/apps/grass/grass-$VERSION/lib/*.dll
 mv $OSGEO4W_ROOT_MSYS/apps/grass/grass-$VERSION/include/grass/config.h
 $OSGEO4W_ROOT_MSYS/apps/grass/grass-$VERSION/include/grass/config.h.mingw
 cp mswindows/osgeo4w/config.h.switch
 cp mswindows/osgeo4w/config.h.vc
 cp mswindows/osgeo4w/grass64.bat.tmpl
 $OSGEO4W_ROOT_MSYS/bin/grass64.bat.tmpl
 cp mswindows/osgeo4w/ini.bat.tmpl
 $OSGEO4W_ROOT_MSYS/etc/ini/grass.bat.tmpl
 cp mswindows/osgeo4w/postinstall.bat
 $OSGEO4W_ROOT_MSYS/etc/postinstall/grass.bat
 cp mswindows/osgeo4w/preremove.bat
 $OSGEO4W_ROOT_MSYS/etc/preremove/grass.bat
 #cp /c/mingw/bin/libgnurx-0.dll $OSGEO_ROOT_MSYS/bin
 #cp /c/mingw/bin/libiconv-2.dll $OSGEO_ROOT_MSYS/bin
 #cp /c/mingw/bin/libintl-8.dll $OSGEO_ROOT_MSYS/bin
 P=$(pwd -W)
 P=${P//\//\\\\}\\\\dist.i686-pc-mingw32
 sed -e "s#$P#@osgeo4w@#"
 $OSGEO4W_ROOT_MSYS/apps/grass/grass-$VERSION/etc/fontcap
 >$OSGEO4W_ROOT_MSYS/apps/grass/grass-$VERSION/etc/fontcap.tmpl
 sed -e "s#$P#@osgeo4w_msys@#" $OSGEO4W_ROOT_MSYS/apps/grass/bin/grass64
 >$OSGEO4W_ROOT_MSYS/apps/grass/bin/grass64.tmpl
 rm $OSGEO4W_ROOT_MSYS/apps/grass/grass-$VERSION/etc/fontcap
 echo $(date): END
 ) | tee -a mswindows/osgeo4w/package.log
 (1)after compiling, in C:\OSGeo4W\usr\src\grass64svn\dist.i686-pc-mingw32
 there are following files/folders:
 AUTHORS
 bin
 bwidget
 CHANGES
 COPYING
 demolocation
 docs
 driver
 etc
 fonts
 GPL.TXT
 grass64.tmp
 include
 lib
 locale
 log.txt
 REQUIREMENTS.html
 scripts
 tools
 so contributors.csv and translators.csv seems to be missed and therefore
 also not in C:\OSGeo4W\apps\grass\grass-6.4.1svn after installing
 (2)
 in C:\OSGeo4W\usr\src\grass64svn\bin.i686-pc-mingw32 there are following
 files:
 grass64
 grass64.bat
 a few weeks ago the files, adapted for the path etc., were installed in
 C:\OSGeo4W\apps\grass\bin.
 now there is only an empty grass64.tmpl in C:\OSGeo4W\apps\grass\bin
 and in C:\OSGeo4W\bin there is grass64.bat.tmpl and in C:\OSGeo4W\bin\bin
 there are the two files grass64 and grass64.bat (but not adapted for the
 path)
 and in the installation-log there is following message:
 Following modules are missing the 'description.html' file in src code:
 GRASS GIS compilation log
 Started compilation: Sat Oct 30 17:35:17 GMT 2010
 Errors in:
 No errors detected.
 Finished compilation: Sat Oct 30 18:45:00 GMT 2010
 Sat Oct 30 18:45:00 GMT 2010: STARTING make install
 include/Make/Doxygen.make:13: warning: overriding commands for target
 `htmldocs
 -single'
 include/Make/Docs.make:11: warning: ignoring old commands for target
 `htmldocs-
 single'
 include/Make/Doxygen.make:19: warning: overriding commands for target
 `htmldocs
 include/Make/Docs.make:38: warning: ignoring old commands for target
 `htmldocs'
 include/Make/Doxygen.make:39: warning: overriding commands for target
 `pdfdocs'
 include/Make/Docs.make:49: warning: ignoring old commands for target
 `pdfdocs'
 include/Make/Doxygen.make:51: warning: overriding commands for target
 `cleandoc
 s'
 include/Make/Docs.make:55: warning: ignoring old commands for target
 `cleandocs
 echo /c/osgeo4w/usr/src/grass64svn/bin.i686-pc-mingw32/grass64
 `htmldocs
 -single'
 include/Make/Docs.make:11: make[1]: Entering directory
 `/c/osgeo4w/usr/src/gras
 s64svn'
 warning: ignoring old commands for target `htmldocs-single'
 `htmldocs
 `htmldocs'
 `pdfdocs'
 `pdfdocs'
 `cleandoc
 s'
 `cleandocs
 test -d /c/OSGeo4W/apps/grass/grass-6.4.1svn || mkdir -p -m 755
 /c/OSGeo4W/apps
 test -d /c/OSGeo4W/bin/bin || mkdir -p -m 755 /c/OSGeo4W/bin/bin
 sed -e "s#^GISBASE.*#GISBASE=/c/OSGeo4W/apps/grass/grass-6.4.1svn#"
 /c/osgeo4w/
 usr/src/grass64svn/bin.i686-pc-mingw32/grass64 >
 /c/OSGeo4W/bin/bin/grass64
 chmod a+x /c/OSGeo4W/bin/bin/grass64
 sed -e "s#WINGISBASE=.*#WINGISBASE=/c/OSGeo4W/apps/grass/grass-6.4.1svn#"
 /c/os
 geo4w/usr/src/grass64svn/bin.i686-pc-mingw32/grass64.bat >
 rass64.bat
 chmod a+x /c/OSGeo4W/bin/bin/grass64.bat
 cd /c/osgeo4w/usr/src/grass64svn/dist.i686-pc-mingw32 ; tar cBf - AUTHORS
 COPYI
 NG CHANGES REQUIREMENTS.html GPL.TXT | (cd
 ; tar xBf - ) 2>/dev/null
 cd /c/osgeo4w/usr/src/grass64svn/dist.i686-pc-mingw32 ; tar cBf - bin |
 (cd /c/
 OSGeo4W/apps/grass/grass-6.4.1svn ; tar xBf - ) 2>/dev/null
 cd /c/osgeo4w/usr/src/grass64svn/dist.i686-pc-mingw32 ; tar cBf - bwidget
 | (cd
 /c/OSGeo4W/apps/grass/grass-6.4.1svn ; tar xBf - ) 2>/dev/null
 cd /c/osgeo4w/usr/src/grass64svn/dist.i686-pc-mingw32 ; tar cBf - docs |
 (cd /c
 cd /c/osgeo4w/usr/src/grass64svn/dist.i686-pc-mingw32 ; tar cBf - driver |
 (cd
 cd /c/osgeo4w/usr/src/grass64svn/dist.i686-pc-mingw32 ; tar cBf - etc |
 (cd /c/
 cd /c/osgeo4w/usr/src/grass64svn/dist.i686-pc-mingw32 ; tar cBf - fonts |
 (cd /
 cd /c/osgeo4w/usr/src/grass64svn/dist.i686-pc-mingw32 ; tar cBf - man |
 (cd /c/
 tar: man: Cannot stat: No such file or directory
 tar: Error exit delayed from previous errors
 cd /c/osgeo4w/usr/src/grass64svn/dist.i686-pc-mingw32 ; tar cBf - scripts
 | (cd
 cd /c/osgeo4w/usr/src/grass64svn/dist.i686-pc-mingw32 ; tar cBf - tools |
 (cd /
 if [ 1 -eq 1 ] ; then cd /c/osgeo4w/usr/src/grass64svn/dist.i686-pc-
 mingw32 ; t
 ar cBf - locale | (cd /c/OSGeo4W/apps/grass/grass-6.4.1svn ; tar xBf - )
 2>/dev
 /null ; fi
 cd /c/osgeo4w/usr/src/grass64svn/dist.i686-pc-mingw32 ; tar cBf - include
 | (cd
 cd /c/osgeo4w/usr/src/grass64svn/dist.i686-pc-mingw32 ; tar cBf - lib |
 (cd /c/
 sed 's#'/c/osgeo4w/usr/src/grass64svn/dist.i686-pc-
 mingw32'#'/c/OSGeo4W/apps/gr
 ass/grass-6.4.1svn'#g' /c/osgeo4w/usr/src/grass64svn/dist.i686-pc-
 mingw32/etc/m
 onitorcap > /c/OSGeo4W/apps/grass/grass-6.4.1svn/etc/monitorcap
 mingw32/etc/f
 ontcap > /c/OSGeo4W/apps/grass/grass-6.4.1svn/etc/fontcap
 chmod -R a+rX /c/OSGeo4W/apps/grass/grass-6.4.1svn 2>/dev/null
 tar cBf - gem/skeleton | (cd /c/OSGeo4W/apps/grass/grass-6.4.1svn/etc ;
 tar xBf
 - ) 2>/dev/null
 tar: gem/skeleton/.svn/text-base: file changed as we read it
 /bin/install -c  gem/gem64 /c/OSGeo4W/bin/bin 2>/dev/null
 make[1]: [real-install] Error 1 (ignored)
 make[1]: Leaving directory `/c/osgeo4w/usr/src/grass64svn'
 Sat Oct 30 18:46:41 GMT 2010: STARTING cleanup
 sed: can't read /c/OSGeo4W/apps/grass/bin/grass64: No such file or
 directory
 so the sed-command can't find the file in C:\OSGeo4W\apps\grass\bin,
 because it's partly in C:\OSGeo4W\bin and in C:\OSGeo4W\bin\bin
 directory
 AFAICT a few weeks ago this issues weren't there.
 Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1207>
